Well here is my Jeep. I'll start this thread with two pictures. The way it was when purchased and the way it sits today. This first entry will be updated as time progresses to include the most current "today" picture and what mods are currently on it. Entries will be made containing details.
As originally purchased (July 2010)
As of Today (Here she is ready for summer 5-16-2012)
Current Specs
Engine
- Stock 4.0L 6 Cylinder
- K&N Air Filter (P/N 33-2114)
- Rugged Ridge Oil Pan (JC Whitney P/N O321743702)
Interior
- Original
CB Radio
Armor
- Currie Rock Ribz Rocker Panel Guards (Poison Spyder P/N CE-9093SRR)
- Skid Row oil pan and transmission skid plate (SkidRow P/N JP-0009 Rev O)
- TeraFlex Steering box skid plate (included in lift kit)
Bumpers
- Currie RockJock 45" Wide V-Front Bumper TJ/LJ (Poison Spyder P/N CE-9094V) - With CFS Off-road custom made hood hoop and stinger.
- Currie Rock Crawler II Rear Bumper TJ/LJ (Poison Spyder P/N CE-9065)
Winch
- Warn 9.5ti
- 100' of 3/8" WARN Spydura Synthetic Rope
- 12VoltGuy Dash Mount winch controls
Drivetrain
- Stock 231 Transfer Case
- Stock 5 speed manual transmission
- Front driveshaft re-tubed (Carolina Driveline)
- New rear SYE driveshaft (Carolina Driveline)
- ARB Mini Compressor (ECGS P/N CKSA12-ARB)
- Advance Adapter Slip Yoke Eliminator Kit (ECGS P/N 50-7906)
Front Axle
Wheels & Tires
- BF Goodrich M/T KM2 35x12.5x15
- TrailReady Aluminum Beadlocks (Baja Style) 15x8 with 5 on 4.5 bolt pattern
Suspension
- TeraFlex TJ Wrangler 3" Lift Kit with shocks and accessories (P/N 1241300)
- Rough Country X-Flex Adjustable Control Arms (Front, Lower from Clemson 4 Wheel Center, P/N R-C-1199)
- Rusty's Upper Control Arms (Front, Upper)
- Rubicon Express adjustable track bar (Quadratec part # 16311 602 07)
- .75 inch Teraflex coil spacers (Quadratec part # 16190 2001)
- Old Man Emu bump stop spacers (Quadratec part # 16090 1119)
- Summer: Bestop Strapless Bikini top (Quadratec part # 11125 15 07)
- Summer: Black Denim Windjammer (Quadtratec part # 11128 15 07)
- Summer: Black Denim Duster Deck Cover (Quadratec part # 11154 15 07)
- Winter: Bestop OEM Sailcloth soft top with tented windows (Quadratec part # 11135 115 07)
Doors
- Winter: Full metal doors
- Summer: Bestop canvas half doors (Quadratec part # 11141 15 07)
Miscellanious
- Gr8tops Exogate Tailgate kit (P/N GR8-XOG)
- Daystar Hood Wranglers (Quadratec part # 16053 5010)
Items broken over the life of the Jeep
- Rear lower control arms, stock, (qty 2)
- Rear lower control arm axle side bracket
- Rear ARB locker, leaked air inside the housing
- Rear tail light, stock
- Axle side sway bar mount, ripped off
- Teraflex rear shocks, (Qty 2)
- Warn hub conversion manual locking hubs, (qty 5)
- Transmission mount
- Radiator
- Throttle position sensor
- Fan clutch
- Water pump
- Warn Dana 30 short side front axle shaft, broken ear when u-joint went
- Front upper control arms, stock, (qty 2)
- Dana 30 u-joint, 297, (qty 2)
- Dana 30 yoke
- Front drive shaft
- Rear drive shaft, (qty 2)
- Dana 30 Ring and Pinion (qty 2)
- Rusty's Tie Rod Ends - driver side - bent (qty 2)
- Hood tie down (qty 1)
Thank you for your interest in my build. I will add build pictures after this main post. Let me know if you have any questions. I'll answer as best I can.
Current Specs
Engine
Interior
- Original
CB Radio
- Cobra 29LTD *US Army* Limited Edition CB radio (WalcottCB P/N ?, can't get it anymore)
- Firestick 4' Antenna (WalcottCB P/N FS464A8AB)
- Trucker speaker (WalcottCB P/N CB980, mouted over rear-view mirror)
- Antenna mount drivers side (WalcottCB P/N CBML, mounts antenna over tail light)
- RAM 111 Pedestal Mount (WalcottCB P/N RAM111, allows mounting of radio on passenger side of tunnel, folds radio down to allow seat to slide forward)
Armor
Bumpers
Winch
- Warn 9.5ti
Drivetrain
Front Axle
- Dana 30
- 4.88 Gears
- Lockright Locker
- Warn Hub Conversion Kit
- Warn Chromoloy Inner Shafts
- Alloy USA Tube Seals
- Rancho Dana 30 Diff Cover (Quadratec P/N: RS6218)
- Currie Johnny Joint kit for upper control arm brackets, axle side
- GoFerIt Flipped Tierod Insert
- Rubicon Express LCA Axle Brackets
- Synergy Heavy Duty Ball Joints
- Rusty's Heavy Duty Tie Rod (Rusty's P/N RS-TR125-UV)
Rear Axle- 4.88 Gears
- Lockright Locker
- Built by East Coast Gear Supply
- Ford 8.8
- TJ axle brackets
- Tubes welded into carrier
- 31 spline Yukon chromoly shafts
- 4.88 gears
- Axle bearing seal kit
- Solid diff cover
- C-Clip eliminator kit
- SYE flange
- setup for 3" lift
- ARB Air Locker
- Currie Adjustable Upper Control Arms w/Johnny Joints (rear) (ECGS P/N CE-9103)
- Ford 8.8
- TJ axle brackets
- 4.88 gears
- Solid diff cover
- SYE flange
- setup for 3" lift
- ARB Air Locker
Wheels & Tires
Suspension
- Springs
- Rear sway bar links
- Rear trackbar bracket
- Swaybar disconnects
- Steering box skid plate (mentioned also under Armor)
- Bumpstops
- Shocks
- And all necessary hardware for installation
- Custom made rear lower control arms (2" x 1/4" DOM with Johnny Joints)- Rear sway bar links
- Bumpstops
- Shocks
Doors
Miscellanious
- Radiator
- Fan clutch
- Water pump
- Dana 30 yoke
- Front drive shaft
