I wouldnt do 60/14bolt unless you going to go with atleast 37s. Your going to lose ground clearance under those axles with small tires. 37s would be the MINIMUM, Id say 40s would be good.
I wanted to go that route with my rubicon but not feasible with funds that I want to spend.
Id say check around and look for rubi44s you got gears and a good axle. Some say rubi axles are weak but when you run 35s-37s and wheel hard anything could be weak. Im on 33 right now but Im thinking of getting 4.88s next time around due to power I lost. Its not bad but I dont like it. Too much power got lost when I switched to 33s.
Id say start with 2.5 lift and 265s power was decent there.
Definitly look in too rubi44s though. I dont think you can go wrong with those. All depends on what size tire you want to go with. Some people wheel fine with 44s and 37s, its just boils down to how hard you wheel.
