Well i finally got everything back together after changing my exhaust manifold. went to start it and it would only crank but not turn over. Similar as if it wasn't getting fuel or spark. Checked pressure on the fuel rail (via the schrader valve) and sprayed fuel so seems ok. Haven't checked spark but it has a new coil less then 6 months old. It has all the symptoms of a bad crank position sensor but that was also replaced within the past 6 months.
Any ideas? Thought about trying another cps but they are a little pricey considering im not positive thats the problem.
