So here is the start of this 99 tj build. Starting off I picked up this one owner 99 tj saraha with 77k original miles after parting with my xj chassis and keeping all the good parts to put into the tj. Plans are (and some of this has already been done) strip the jeep down to only what I'm going to use. I got rid of the front fender, all of the interior, axles tires and wheels, bumpers ect I think you get the point, I got rid of a ton of factory parts, to recoup a hefty portion of what I bought the jeep for. As of now I have pulled and rebuilt the transfercase with a upgraded 1350 rear cv yoke, chopes the rear frame off and installed the motobilt tj backhalf kit, and removed all of the factory suspension brackets. I will be running 14 inch radflo coilovers up front and 16 inch foa out back, plan as of today is 3 link the front and 4 link the rear. If I decide to go ahead and go full hydro steering I'll do a front double triangulated 4 link and nix the 3 link and pan hard bar. Axles are a 05+ ford 60 with 1550 shafts and barnes weld on high steer arms and tmr truss and 14 bolt rear stock shafts , both are stuffed with 5.38s and welded up spiders because I'm too cheap to buy actual lockers. 39 reds on h2 wheels, Motobilt 15 gal tj fuel cell with all -8an fitting and braided line will replace all of the factory fuel line. I bought the motobilt front A-pillars and will bend up a front half kit for the cage. I'm sure there is more I'm forgetting but that's a start for now. This will be a slow build up but I'll update this thread as I check things off the list.
