What did you do to your rc this week?
#23
I installed my cvds last night,(nice and smooth) I couldn't use the long through shaft set screws due to mips being a larger screw. Went to install my new CVDs on the 1/16 Revo, that's a several hours process involving removing the diffs and what not, tossed it back on the shelf.. Pulled out my nitro truck to put a radio back in it, Paired the RX to my 4pl, then fought with it for a hour trying to fidgure out how to work the Model memory... Well to sum it up... 5 min of actual work hour and a half of giving up...
#25
Neverrrrrrr!!! Uh not sure I'm working this weekend and I'm busy pretty much until the 20th.... Unless you wanna come pick it up from Lexington you can get it whenever
01tj
Guest
#26
Pulled the trans out, and the bolts were loose that hold the case togather. Tightend them up and put it back togather, still got the same problem.
01tj
Guest
#29
I cracked the trans open today and the gears looked fine. What is the slipper clutch supposed to look like? There was some sticky stuff hanging out the sides of the clutch and when I pulled it apart it was just metal on metal.
#30
sounds like thats your problem, it should be a paper like disk in there between the metal. sounds like you burnt up the clutch, must have been too loose.
01tj
Guest
#39
Ive got to get mine going now after driving Chads. I will need more wheel speed once I get it going agian!!!
