Well my build has hit the fast forward button, so I'm shedding some parts sooner than expected. Everything is coming off of my 98 TJ, so most parts either fit a 97-02 TJ, are universal, or will be listed in the item description.
Genright TJ stretch corners and hiline tube flares. Everything is already cut and trimmed to fit together, all that you will need to do it trim your stock tub. The corners are painted moss green pearl (PGN) and the flares are flat black. The corners have the holes for tail lights and the rear hinges. For the moment there is no hardware for the corners, but I will be glad to throw in the bolts and nutserts that come with my new corners. Looking to get $400 for corners and flares.
http://www.genright.com/ProductInfo.aspx?productid=CNR2003
http://www.genright.com/ProductInfo.aspx?productid=TFR1020
OME 2.5 HD TJ coils (Front and rears). These were only used for one wheeling trip and maybe 50 road miles. They still look brand new and have the tags on them. These are the HD springs, so they will net 3"s or so with a moderately armored TJ. Looking to get $200 for the full set.
JKS TJ ACOSs front and rear. These are the adjustable coil springs spacers that give you the height adjustability of a coilover with your springs. These are the first generation ACOSs that just had new poly isolators put on them last year. Looking to get $200 for both sets, or $125 for the fronts and $75 for the rears.
http://store.jksmfg.com/merchant2/m...OS&Store_Code=JKS01&Category_Code=Coil_Spring
BBCS 11Cs, one pair of 11" travel shocks, valved for coil spring suspension, that are basically new. Looking for get $150 for the pair.
http://www.polyperformance.com/shop/BBCS-Shocks-p-84.html
Other stuff that is coming off in the near future too, but will set a price once it comes off:
TNT truss for a 77.5-79 ford hp60 that has coil buckets set for a 2" front stretch, OTK trace bar bracket, assist ram mount, upper link mount frenched into truss, and more thank likely the TNT trace bar will go with it too.
