The Morning Doo
01tj
Guest
Someone at work just emailed me this:
Urban Dictionary’s definition of “Rollin’ Coal”
1. Rollin' Coal
When stupid-*** white trash people turn the injection pump up on rickety-*** broken down 12V Cummins-powered Dodges and subsequently install 5" smokestacks in the bed of said Dodge. Then said WT decides to post youtube videos of their truck blanketing neighborhoods with black diesel soot.
Regardless of engine technology progressing to the point of nearly eliminating black smoke and producing nearly double the power of modded mechanically-injected diesel engine in stock form, a "Coal Rollin'" owner will respond with a not-so-clever response of "I'd rather be Cummin than Strokin." Referring to his belief that his Cummins engine is better than International's Powerstroke engine series found in Ford trucks. Because Isuzu's Duramax engien found in GM-branded trucks cannot be directly correlated to any phallic self-gratification, they are typically ignored. See Below for why
This particular stereotype is the progression of the IROC Camaro owner in the 1990s and the lowered Civic Hatchback owner in the early 2000s. They can be identified by their love of Nickelback, lack of personal hygiene, closeted homosexuality and morbid obesity. A majority of these owners reside in Florida, this species also can be found in eastern Texas, Alabama, Georgia, and California's central valley.
"Check 'er out fellas I was rollin' coal through that there intersection antagonizing queers. Y'all want to get naked and jump in a mudhole together?"
1. Rollin' Coal
sounds about right to me
WolfGT
OK, some cool stuff to check out during your morning doo. These videos are way cool and you may just learn something.
Here is his channel, it's called Smarter Every Day.
Here is the video that hooked me, AK47 underwater in slomo. Make sure you crank up the resolution.
[video=youtube_share;cp5gdUHFGIQ]http://youtu.be/cp5gdUHFGIQ[/video]
WolfGT
OMG! The ultimate Morning Doo video.
Watch, learn and practice regularly! LOL, now you will think about me every time!
[video=youtube;-XNDM4eAn1U]http://www.youtube.com/watch?v=-XNDM4eAn1U&feature=share&list=PLBCFA347CE84FD2A9[/video]
WolfGT
Ok, you know when you hear the "if you experience an erection for more than 4 hours ..... blah blah blah" warning and you kind of giggle? Watch and learn. I don't think I'll ever even try ED drugs after seeing this.
[video=youtube;JN0VtHez9xI]http://www.youtube.com/watch?v=JN0VtHez9xI&feature=share&list=UU6107grRI4m0o2-emgoDnAA[/video]
Cliff notes?
WolfGT
Basically when a man gets excited the body releases a chemical that opens the valves in the penis that allows the blood in. Then after the man climaxes, the body releases another chemical to open a valve that releases that blood. The spider bite basically injects you with a high dose of the first chemical but since there was no excitement, just pain, the second chemical never gets introduced so the blood sits in your junk and turns into a thick syrup because of the lack of oxygen causing permanent damage. So that is why you are supposed to go to the doctor if it lasts more than 4 hours. Now for the bad part. The remedy is a huge *** needle that they have to repeatedly stick into your junk to drain the bad blood (the needle has to be big and thick due to the really thick consistency of the blood). But since the chemical that caused the issue is still in effect, it keeps filling back up. After jabbing you many many times, the next step is to jab a scalpel in the end of your junk and ream it out to allow it to drain. At this point, your junk is probably permanently broken.
