Rhino water pump
Anyone ever had to replace a mechanical seal on a water pump of a rhino water pump? im having problems removing the impeller shaft of the water pump.
once you remove the impeller you need to get a small drill bit and put a hole in the seal. Be careful not to drill to deep,just go threw the seal. Then screw a screw in it but once again dont screw it in far, just enough to get a bite. use a small dent puller or vice grips and and a pry bar and pull it out.
Once you do 1 you will see how easy it is.
