Okay so as some of y'all know i recently bought a pontoon. Its got a 98 50hp johnson 2 cyl 2 stroke. It runs great at everything other than idle. I don't have a tach but i'd say at everything over 2000 rpm. Runs great wide open. When its at idle it is only running on one cylinder. I found that out when i pulled the plug wires. I am getting spark to both cylinders because the sucker shocked me both times. But I'm not sure how strong of a shock. I also replaced both plugs
On the cylinder that isn't running at idle, I think the carburetor is the issue. When i pulled off the flame arrestor there was fuel puked up all around the carburetor. And on the top of the carb where the primer goes in it had a pretty good residue of gas. around it. I cleaned it, and saw some more starting to squeeze out. I'm by no means an expert on these things so any thoughts will help.
