I expect it to be pretty expensive, probably along the same lines as an LS1 connect and cruise package
But seriously it's cool that they're offering the repower package and it could make a neat swap. I'd put one in Frank!
The problem with diesel engine swaps is you have to be planning for the diesel from the start. Consider a Samurai, since thats what i have experience with. If you have a stock motor Sami with 6.5 case and 5.38 gears, and decide to do an engine swap, you go with a 1.6 16v and you have power from 1,000 rpm - 7,000 rpm. If you do a vw diesel, you only have a redline of say 3,500 rpm. You can only spin the tires half as fast in each gear. To get wheel speed back, you need to regear to 3.73/4.10 and swap in a 4.16 or 4.9 case.
