I have a set of 4 37x14r15 Bias Iroks for sale. Mounted on 15x8 rock crawler wheels, 2.5"BS, 5x5.5 pattern with an MRW beadlock kit installed. Tires are in good shape. Mostly offroad use. Wheels have some rock rash, mainly on the outer ring. Could use some paint but I gave up on that after rubbing off most of the red paint I had done the first trip out.
I won't separate the wheels and tires. They are a PITA to mount and dismount because of the offset. They worked great on the trail (I usually ran 3-4 psi).
$1000 OBO for the set. Located in Augusta GA. Local pickup only.
The rears were worn a bit more than the fronts. The one on the right shows the rear tread. the middle and top in this pic are what I had on the front.
