1946 Willys CJ2a
1948 CJ2a
Lhead 134
T90/Dana 18
Dana 25/Dana 41
5.38 gear ratio
All gear boxes drained, inspected and refilled
All axles Drained, inspected and refilled
Front bearings repacked
New 11 inch brakes front
New Dual chamber Brake MC
New aluminum Radiator
New Alternator
New hoses
New fuel pump
New brake lines
New gas tank
New front floors
New tool box
New seat bottoms
New steering wheel
New wiring
What needs to be done?
Front axle needs pinion seal.
Leaking rear main seal
Transmission will need a rebuild, pops out of second and whining a bit.
Still drives fine, but will need to be done eventually
Tires need to be balanced or looked at. When driven it feels like a bad flatspot.
Body work and paint not the greatest, i am not a body man.
No bondo was used when painted, so you see the patches of metal.
It is an extremely good platform to build on if you want to do a pure restoration.
Fix the little things and have a great local run around.
Do not ask what bottom dollar is, come look at the jeep and negotiate.
$5000 obo. No Trades, unless it is a fj60 or fzj80 Toyota Land Cruiser
