A little back ground, a few weeks ago I purchased a 2003 44 to go into my TJ I replaced the axel shaft bearings and seals the new bearings were the one piece type. I installed the axel in the Jeep and ever since I have had a little weeping at the seals so tonight I pulled the drivers side and when I did the one piece bearing came apart and left the race in the axle tube. I went ahead and put it back together but have not driven it yet. Will I have an issue with that bearing or will it be ok? Just not sure if I need to replace it or not.
