So, Its defiantly not coming out of the vent.
Degreases/Cleaned it up good, then took it around the block (10-15) miles, this is what i found.
It appears to be coming from this plug and somewhere at the rear seal or the bottom/back of the housing.
The SYE leak really appears to be the output yoke seal.
Im not 100% sure i put silicon on the splines but i know it put it on the rubber washer when i installed the yoke and torqued that bitch to 150 ft. lbs.
Mhmmmm - RUSTY.....
