YJ springs
Looking for some 1.5-2.5 yj springs. Or even some larger lift springs I can take apart. Heck even stock spring packs that I can combine with mine.
I don't think adding stock YJ springs to your stock YJ packs will gain you much. But go to your local JY and get a set off rear XJ springs. The main and second leaves can be cut to size and slid into your YJ spring packs for about 2in of lift for under $50-$60.
on that note, we used S10 rear springs as an add a leaf in a Cherokee we built, so I'm guessing they would work in a YJ as well. It really helped with axle wrap.
