Marcus's shocks would actually probably work pretty well for you, cause you and him are about at the same height from what it sounds.
In all seriousness I probably have under a grand in my suspension front and rear. When i built it I had minimal amounts of cash and everything was collected on a tight tight tight budget. That's just to show that doin it right aint gotta be expensive.
Also do you have after market control arms on your jeep? If you have a grand to spend i'd say wrap the jeep with quality short control arms, new shocks, and lower it down to a 2.5 inch lift and you will be fine. You shouldn't need a drop pitman arm either with that set up.
