My lift springs, as well as my OE springs did the same thing.  It's the design of the spring.  They used a 2.5" mount upper & lower, then out to a 7.5" outer diameter spring.  The mounting surface of the spring is so small that under compression it just pushes down in the middle of the spring.  It's not doing any damage, just doesn't look right!
