Brand new in the Box Warn 12k lb winch.
$500 Located in Chapin, SC
Legendary WARN reliability and performance; 12,000 lb. (5440 kg) capacity
Low-profile design will fit most trucks and SUVs
Separate control pack for various mounting options
Exclusive brake design for superior winching control
Durable, smooth, and reliable three-stage planetary geartrain
Series-wound motor for plenty of power and fast line speed
Remote control with 12' (3.7m) lead
94' of 3/8" (28.6m of 9.5mm) diameter wire rope
Backed by the full WARN Limited Lifetime Warranty
Part numbers: 86260
Rated line pull: 12000 lbs. (5443 kgs)
Motor: 12V DC, Series Wound
Electrical controls: Solenoid
Remote Control: Remote switch, 12 ft. (3.7m) Lead
Geartrain: 3-Stage Planetary
Gear ratio: 216:1
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 2.5 in./9.0 in. (6.4cm/23cm)
Weight (kit shipping): 89 lbs. (40.4 kgs)
Wire rope: 3/8 in. x 94 ft. (9.5mm x 28.6m)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72 in. (1.83m)
Finish: Powder coat over primer undercoating
Warranty: Limited Lifetime
This winch retails for $670 and it is exactly as you would get it from a store, it has never been out of the box.
