GenRight Off-Road has a variety of roll-cages designed for the following Jeep models: TJ, LJ, YJ, and CJ!
_____________________________________
Fastback Roll Cage Kit (YJ):
SKU GRC4500
This is the new Fastback style cage from GenRight Off Road. It is a 2 person (driver & passanger) complete replacement cage kit for your Jeep Wrangler YJ (1987 - 1995). This is the BEST & most protective two person cage we offer. All the tubes are cut to length and mitered to fit together, you just need a welder to put it all together!
FEATURES:
Designed for maximum visibility.
Works with Bestop Super Top soft top.
Works with hard of soft doors.
NOT designed for passangers in the back seat!
Made from heavy wall D.O.M. (Drawn Over Mandrel) seamless tubing.
Includes all new Laser Cut and CNC formed heavy duty brackets to mount the cage in your Jeep.
Does NOT require cutting the dash.
Kit can be shipped to you in three boxes.
All the tubes are cut to size and mitered to fit together.
6 point contact design (cage to frame tie in sold separately).
Includes 3 grab handles, as pictured.
Optional re-enforcement bars are available (at the dash and behind the seats) for more protection.
Optional bracket mounting kit to accept all the factory seat belts.
Includes detailed installation instructions.
NOTES:
This KIT requires complete removal of the stock roll bar (and most of the interior).
Full Roll Cage (YJ):
SKU GRC4001
This is a complete replacement roll cage kit for your Jeep YJ. It was carefully designed for maximum foot room and visibility, to fit with a factory hard or soft top. Yes, it has head room for passengers to ride in the back seat too!
It is made from heavy wall 1-3/4" D.O.M. (Drawn Over Mandrel) seamless tubing and includes all new heavy duty 3/16" thick brackets to mount the cage to your Jeeps tub and provide maximum protection to you and your passengers in the event of a roll over.
Kit includes new bungs to mount the factory seat belts (if you choose to re-use factory type seat belts).
Another BIG plus: the kit ships to you by UPS to avoid expensive truck freight.
KIT FEATURES:
Cage kit ties all the way to the floor and still allows you to use factory hard doors.
The BEST foot clearance on the market, with GenRight dash to floor stanchions.
Will still allow you to use your Factory hard or soft top!
Stanchions are 2 pieces so the cage can be removed for paint or powder coat.
Lower leg stanchion also reinforces the tub by bolting through the lower door hinge.
Tough 1-3/4" DOM cage steel tubing.
All new laser cut and CNC bent 3/16" brackets.
6 point mounting.
Includes new mounting hardware.
All the tubes are cut and mitered to fit together (some trimming may be required if your Jeep is not showroom perfect), you just need a welder to put it all together!
Detailed installation instructions are included with the kit.
NOTES:
This kit is sold un-welded - required welding by the end user.
After welding, the cage it is possible to remove the cage for powder coating.
See Cage Options when checking out.
Fastback Roll Cage Kit (TJ):
SKU GRC2500
This is the new Fastback style cage from GenRight Off Road. It is a 2 person (driver & passanger) complete replacement cage kit for your Jeep Wrangler TJ (1997 - 2006). This is the BEST & most protective cage we offer. All the tubes are cut to length and mitered to fit together, you just need a welder to put it all together!
FEATURES:
NO room for back seat passengers!
NEW! Now includes bracket mounting kit to accept all the factory seat belts.
NOTES:
See Cage Options
Sport Cage (TJ):
SKU GRC2002
This is the GenRight Sport Cage for the Jeep TJ, which is a add-on to your Jeeps factory roll bar. It was designed to beef up and complete your factory bar(s) and still provide maximum head room (for all passengers), visibility and to fit with a factory hard or soft top. It even includes 3 additional bars to protect passengers in the back seat!
It is made from heavy .120" thick wall tubing and includes all the necessary brackets & gussets to mount the new cage pieces to your Jeeps existing roll bar.
Another plus: the kit ships to you by UPS in one box. All the tubes are cut to size and mitered to fit together (some trimming may be required if your Jeep is not showroom perfect), you just need a welder to put it all together!
FEATURES:
The kit requires NO cutting of the dash.
The kit includes 3/16" thick brackets that fit next to the dash and extend all the way to the floor.
The cage is sold un-painted, so it can be properly welded together.
This kit requires removal of some stock roll bar pieces for proper fitment of top and doors during the installation process.
Requires a frame tie-in for maximum roll over protection (sold separately GRC-5500).
Full Roll Cage (TJ):
SKU GRC2001
This is the GenRight Off Road complete replacement roll cage kit for your Jeep Wrangler TJ (1997 - 2006).
This is the BEST most protective weld-in cage we offer.
All the tubes are cut to length and notched to fit together you just need a welder to put it all together!
FEATURES:
Designed for maximum visibility with NEW higher visibility dash bar!
Works with factory hard (optional factory soft top adaptor kit is available).
Can be used with hard (full or half) doors or soft doors.
Rear seat head room for passengers!
Laser Cut and notched tubes (as pictured)
Laser Cut and CNC formed heavy duty cage to tub mounting brackets.
Kit can be shipped to you by UPS in three boxes.
All the tubes are cut to size and notched to fit together.
6 point mounting.
Includes detailed step by step installation instructions.
NOTES:
Factory soft top requires a optional adapter kit to re-mount the factory door surrounds. If you want to reuse the factory soft top with no modifications, please purchase our Sport Cage.
SKU GRC4500
FEATURES:
NOTES:
SKU GRC4001
KIT FEATURES:
6 point mounting.
NOTES:
SKU GRC2500
FEATURES:
NOTES:
See Cage Options
Sport Cage (TJ):
SKU GRC2002
FEATURES:
SKU GRC2001
FEATURES:
6 point mounting.
NOTES:
