I have a pretty well built ford 8.8 31 spline that I am selling, it is currently under my jeep if you would like to check it out. It has an artec truss and brackets, solid diff cover, and an ARB air locker. The axles has 3.73 gears and is a direct bolt in to a Jeep TJ with factory control arms. It is about a half in narrower, but has 5x4.5 lug pattern. So you can use the same wheels, as long as you have enough offset on your rims. The axle's truss, and locker were professionally installed at Preformance 4x4. I am asking $1600 obo. This is less than what it would cost to build this axle.
Sent from my SM-G920T using Tapatalk
