Yeah its a disconnect but couldn't you do some bracing on the long side tube and then put in the proper lenght shaft? Seems like you could save some money this way.
its disconnect and balljoint... you can find balljoint 60s for 400-600 every now and then so might as well not get a disconnect. Austin paid 400 for his 80s front 60
Dodge uses external locking hubs on the front is the biggest downfall. The 14 bolt is the smaller ring gear semi float version. Basically the bottom of the barrel when it comes to tons.
