Dana 30HP, 8.8, 33's
Time to clear out some noise to focus on other projects in life.
Just pulled these from the Commando to go back to dana 44's. I believe the axles are 3.73 and the rear has a limited slip, but we can pop the cover to check to make sure.
Front Dana 30, HP, new rotors, pads, steering. Needs a unit bearing and stub shaft (threads are stripped)
Rear 8.8 disk brake - have the 1310 flange adapter to go with it
5 33" Cooper Discovery STT 12.5x15 4 mounted on wheels (1 with plugs in sidewall) 5th unmounted but I have the wheel. 5x4.5". Maybe a couple 1000 miles on them. I used them on my AWD IFS buggy. - plug is visible in the picture.
I would love to sell it all in a single go for $800 if I can.
Located in Easley.
Located in Easley.
View attachment 22436 View attachment 22437
How much for the 8.8 by itself. Got a buddy with a YJ that needs one.
I could let it go for $200. It does have aftermarket leaf spring mounts on there that could likely be cut off and reused. I also have the flange for the 1310 driveshaft that goes with it.
Yeah he will pick it up Wednesday if he can. Can I get your contact info to pass along?
