I bought this a little over a year ago to use on the Wateree River and Lake Wateree. We just don't use it enough and it doesn't need to just sit here. The boat is a 1990 Polar Kraft 16ft with a modified V style hull. It was previously set up for Crappie fishing so it had quite a few rod holders on it that I have removed and only left the ones I found myself using most often. The motor is a 1989 25hp Mariner (built by Mercury). The fuel cell is a 6 gallon with primer bulb and a new quick connect at the motor. It had a transom mount Minn Kota Endura 30 trolling motor attached to the bow. I disassembled it for a rebuild, but it needed too many parts to justify the cost compared to the cost of replacement which is around $90. The battery in it is an Interstate deep cycle that is only 1.5 years old and holds a good charge. I will include the battery tender with the boat. There is a Humminbird Fishfinder that will come with the boat. The screen has a large black spot in the middle, and the transducer needs some epoxy, but I was only using it for the depth since I was running the river.
The trailer is in great shape, and has had plastic skids installed where the boat rests which makes it much easier to load and unload since it slides better than carpet. The bow ratchet is in good working order, and it also has 2 ratchet straps to tie down the rear corners of the boat.
I've got several life jackets, 2 paddles, new whistle, etc to go with the boat.
The boat and motor both have clean SC titles. The boat registration is good through 2017.
*** Just installed new fuel tank and fuel line kit 4/25 ***
I NEED THIS GONE ASAP...MAKE AN OFFER!!!!
