Results 1 to 10 of 10
Thread: Chevy dana 44 front
  1. #1
    Greenville
    116
    Chevy dana 44 front
    I'm in no rush at all here. Just slowly gathering parts for a possible winter project, but I have been planning to put the Jeepster on D44s front and rear for years - as much for the added width as for the added strength. I will be using an Isuzu D44 rear because the track width is right for me, they come with disc brakes, and I can get it already geared at 4.30:1. I intend to use a Chevy D44 front and cut the long side down to match waggy width so I can use stock waggoneer shafts. I can't use a Wagoneer front axle because the pumpkin is in the way of where my springs need to mount.
    So if anyone has a spare chevy axle housing around that they don't need please let me know. I don't necessarily need a carrier (going to put ARB in it with gears to match rear), and I don't necessarily need the long side axle shaft. While I am looking for a deal, I am happy to pay something for it.
    Thanks
  2. #2
    SUPPORTER LBarr2002's Avatar
    Leesville
    3,772
    I don't have one any more, but just a suggestion to broaden your search. Would a J10 front work for you? The distance from pumpkin to C on the short side is like 6" longer I think.
    '04 LJ Sleeper
  3. #3
    Moderator
    Anderson
    sc
    804
    if he would have an issue using a 79-down waggy axle then the j-truck would pose the same problem I would imagine, even though its wider. The mounting width is the same.
    01 Sahara, stuff.
    91 Comanche more stuff
    79 J20 with a 5.9L Cummins
    old man at tellico-"your front wheels werent turning coming up through there"
    me- "thats cause i was in 2"
    old man at tellico- "oh''
  4. #4
    Leesville
    3,772
    Quote Originally Posted by meaders View Post
    Oh yeah, the leaf pad is cast into the pumpkin isn't it?
    Couldn't you shift it over and put a perch on the short side tube and chop the long side as needed?
    '04 LJ Sleeper
  5. #5
    Moderator
    Anderson
    sc
    804
    Quote Originally Posted by LBarr2002 View Post
    probably so, always more than one way to skin a cat.
    01 Sahara, stuff.
  6. #6
    Greenville
    116
    The way I have it planned out will allow me to use stock chevy short side shaft and stock waggy long side shaft - no custom length axle shafts.
  7. #7
    Nov 2017
    LEXINGTON
    20
    You might want to check Facebook Marketplace for your parts. I saw a couple of Chevy Dana 44s on there in the Lexington SC area not too long ago
  8. #8
    Greenville
    116
    Thanks, I'm not on FB much, but I'll try to remember to keep an eye on it.
  9. #9
    Greenville
    2,874
    Meant to send you this the other day when I stumbled across it. Good deal for not having to pull it
    https://greenville.craigslist.org/pt...640273681.html
  10. #10
    Greenville
    116
    I saw that and seriously considered it. I may still go for it...
