Hey TJ/LJ Owners. Aux light switch
I am wiring in a set of factory Jeep TJ aux lights in a Jeep. The light pigtail is already there in the front, so that was easy to plug lgihts in. BUT The jeep did not have aux lights from the factory. So i need to source a switch.
Has anyone used the Daystar Rocker switches in the factory switch holes in the Dash?
https://www.quadratec.com/products/12500_24X_PG.htm
Or what have you been using to fill the stock location?
I am hoping the other side of the wiring is zip tied behind the dash.
#4
Actually this was easier than i thought. This is a later TJ and it has the aux lights in teh turn signal stank. Plugged the lights in and they work, but the contacts seem to be dirty, the are flicking on and off when you dim the interior lights for some reason
