I didn't make the 1st meeting of the new year, but I hope everyone in doing well.
If any of this was covered at the meeting, then moderators feel free to edit as needed.
**If anyone needs a specially tool to complete a job, let me know ahead of time. I'm happy to bring what I have, just need to know what to pack.**
I'll go ahead and bring......
*My tablet running Torque, with OBD2 adapter to scan\clear codes, and watch live data.
*Factory Parts Listings for
1994-1996 YJ \ XJ \ ZJ
2003 TJ
*Factory Service Manuals for
1994 YJ \ XJ
2003 TJ
*Cooling system pressure tester, if anyone is having trouble locating a coolant leak.
*Cooling system chemical tester, if someone thinks they may have a crack in the block, or minute head gasket leak.
*Multimeter, digital Circuit tester, Power Probe electrical diagnostics.
*Mini torch if anyone needs to soulder battery cable, or power wire ends.
*Connector crimpers for OE terminal repairs. (Just bring the terminals you need replaced)
If you need help wiring any electronics, I'll be happy to explain, and supervise. Sorry, but my back doesn't agree with crawling all around a vehicle now days.
(Let me know what you want installed, and I can tell you exactly what size wire, fuse, relay, switch, ect.... you will need to bring. )
If anyone has old towels, shirts that can be cut for shop rags, please bring them I'm sure we will need them.
If your doing anything with fluids, bring something to catch it, and take it home with you.
Bring brake cleaner for brakes, drive line, or fluids clean up. Walmart brand is fairly cheap.
IF YOUR VEHICLE SMELLS LIKE FUNKY MUD, OR SO GREASY YOU CAN'T SEE THE MOTOR, GO WASH IT OFF!
Sent from my SM-N950U using Tapatalk
