Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: White TJ build
  1. #61
    SUPPORTER VOLT's Avatar
    Greenwood
    2,147
    Yeah the hardtop certainly rules out the CJ latches. I think you would need to just cut out the whole area were the hinges are so that they rest on the tub again to reinstall the factory ones. I donít know if it would seal or latch right otherwise.
    #oscarisaliveanddoingwell
    #hillkillingsux
    #marcuscountsrockbouncersinhissleep
  2. #62
    Greenwood
    2,147
    Never mind. I just read about the spacer plates above.
    #hillkillingsux
  3. #63
    Greenwood
    134
    Quote Originally Posted by VOLT View Post
    Yeah motobilt was nice enough to send me those plates lol. Honestly, didnít know what they were at first
  4. #64
    SUPPORTER matth_85's Avatar
    Hodges
    5,208
    There should be a fairly simple clean looking solution. Get you a CJ Tailgate if that's what you want to run and I'm sure you or someone can come up with something. You're welcome to borrow my tailgate to mock something up if you want.
    Maybe just run a different weather stripping on the window would allow it to seal and pull past. Not sure what that gap actually would be though.
  5. #65
    Greenwood
    134
    Quote Originally Posted by matth_85 View Post
    Eh donít necessarily want a CJ tailgate. I think it would be sweet but nothin I care to put money into now. Think Iíve decided to say screw it and just put the spacers in the tailgate and drill some holes in the corners for hung mounts
  6. #66
    Greenwood
    134
    Got the holes drilled for the tailgate hinge. Wasnít too bad. Still need to add the spacer plates to the tailgate itself but did get the corners and cowl sent off to Bud today so Iím ready to see how those turn out once installed.
    Also, maxbilt made their order right and sent me a driver taillight and a return slip so I could ship the extra passenger side one back to them.
  7. #67
    Greenwood
    134
    Waiting on my fenders to come back from paint so I got my rear shock mounts frenched in today. Wasnít to bad but Iíve only got about 9-10Ē of travel. Way I set this up I got 5Ē downtravel and 4Ē up.
  8. #68
    Greenwood
    134
    White TJ build
    Did a little more tinkering today. Mounted the shocks and took a hot lap around the neighborhood. They are rubbing just a slight bit, I knew it would be close, but I think a lil flap disk will take care of it
    Painted my mounting hardware for my rear corners since I havenít found stainless hardware yet. Added the spacer for the tailgate hinge. Painted them white with some left over paint I had. And also mounted my license plate in my old Tire carrier location. Not sure what or if Iím going to do about a tag light, suggestions welcome.
    Also did a ballpark alignment on the front and shortened the draglink to gain more ďleftĒ turning radius. Got lucky and somehow the steering wheel is even centered now when Iím going straight. Took it around the neighborhood again and it tracks straight and feels good!
