Ralleycross....it's awn
Does that thing have std. steel wheels? If so I'd look into some alum wheels for down there. Those steel wheels break the centers out super easy.
Usually steel or forged aluminum is required. Cast aluminum will Crack easier
There are no requirements per jimbob. You ever watched a FWD car lose a wheel going into a turn? The steel wheel breaks the center out from force back and forth. They are made from pot **** metal.
Everything I have been reading the wheels haven't come up as an issue. I am going to scoop a few extry wheels though now that's it's on my mind. On the courses with a lot of whoops and jumps the problem is control arms, and some roll pin in the trans.
i wouldnt see any reason why not. They just dont want really tall stuff from what i read. Guys on pirate talked about racing rangers. I would assume you would be modified rwd.
#18
Dent resistant son....the panels are all pre painted and removal. The main car structure is black and the panels are painted and then installed.
