Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Ugly Drum Smoker
  1. #51
    SUPPORTER 97TJGUZZY's Avatar
    Join Date
    Feb 2011
    City
    Chapin
    State
    SC
    Posts
    11,874
    did some spare ribs on the smoker and dam, those are like pulled pork and ribs put together. Plus you can cook them in 3 hours.
    --Brooks
  2. #52
    SUPPORTER Steve97tj's Avatar
    Join Date
    Feb 2011
    City
    Greenville
    State
    SC
    Posts
    2,875
    First time using the smoker. Need to get the temp control figured out but I ended up with a good product. Threw the meat on at 1230, had to add charcoal at 3:30 and flipped it over then came back an hr later and wrapped it in tinfoil and put in an apple juice liquid to steam in until I removed it completely when I got home at 9 probably. The rub was a little heavy for me but Melissa said she liked it.
    Used a 3.75-4lbs boston butt and used a combo of lump and briquettes with some cherry chips I had laying around.
    I may have jumped the gun at first bc the temp was only like 200 degrees and with my 3 bottom vents open it wouldn't go much higher then that until I added more coal then it jumped way up to like 300-350 so I covered two of the vents up and cut my valve back
  3. #53
    SUPPORTER matth_85's Avatar
    Join Date
    Feb 2011
    City
    Hodges
    State
    SC
    Posts
    5,302
    Nom nom nom, sure do wish bi-lo would put some loin or butts on sale before the 4th.
    Harvard
  4. #54
    Join Date
    Feb 2011
    City
    Chapin
    State
    SC
    Posts
    11,874
    cant tell from that pic, how big is your charcoal basket? Mine will usually run for around 12 hours on one load.
    --Brooks
  5. #55
    Join Date
    Feb 2011
    City
    Lexington
    State
    SC
    Posts
    1,361
    I started my new smoker yesterday. 1/4 inch plate all around. Just the cook box itself without even full welding or grate, it must be over 100 pounds. This is gonna be a heavy pig :)
  6. #56
    Join Date
    Feb 2011
    City
    Hodges
    State
    SC
    Posts
    5,302
    Post some pics. I am thinking about building me something pretty soon. It will likely be a pull behind unit though bc I do a lot of cooking at the lake rather than the house.
    Harvard
  7. #57
    Join Date
    Feb 2011
    City
    Greenville
    State
    SC
    Posts
    2,875
    I was more or less just adding it to keep it going for sure while I was gone for several hours. I probably had maybe 5lbs of charcoal In there at first and felt like it had burnt a lot more of it then I expected when I checked on it. I'll can't remember what the bottom grate on my basket is but I think it's like 18.5" maybe. This was my first time using it and first time smoking on a charcoal fueled smoker so there is some learning to be had with the fueling of the fire.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
